Re: Power window install Help
bcm and door wiring harness are required, and you still may have a problem. I am not sure if the dash harness is the same or not. Someone steering you wrong. The XE is the step-child and doesn't have all the same wiring as all the other versions. Also if you have a XE KC, the foglight wiring is not there either.
