Re: Power window install Help
When I started this I was told that the Wiring was all the same, obviously that isnt the case. I found great deals on the parts I have right now.
Drivers and passenger side factory switches $75
LH Power window Regulator & Motor $65
RH Power window Regulator & motor $55
Im already about $200 into it, so Im asking myself where do I go from here?
If I can end up under $400 with the wiring and BCM That still saves me $200-$300 from what the dealer is asking.
There is a Nissan dealership by me that can get me the wiring harness's I need for $44 each side.
Im going to call and ask about the BCM for an SE.
So I guess Im pretty motivated to get the factory power windows and switches working.
Getting the Harness's and BCM should do it right? Anything else you guys can think of?
