Old 04-28-2009, 03:08 PM   #7 (permalink)
TxTitan09
Re: Power window install Help
Originally Posted by tgmotoman View Post
bcm and door wiring harness are required, and you still may have a problem. I am not sure if the dash harness is the same or not. Someone steering you wrong. The XE is the step-child and doesn't have all the same wiring as all the other versions. Also if you have a XE KC, the foglight wiring is not there either.
Your right Fog light Harness isnt there I checked. The SE BCM should fix this if I get the fog light harness right? The dash harness is the same I checked with Nissan, just not the door harness.
TxTitan09 is offline   Reply With Quote
