The aftermarket spacers are rubber because they go between the top plate and the spring. S4titan's spacer is just moving the attachment point of the strut downward, the same thing that is done with the CST lift, only to a lesser degree. Ride should not be effected because the spring rate is not changed.
-Counsel Yourself
