Old 08-16-2004, 12:13 AM   #10 (permalink)
S4Titan
S4Titan's Avatar
Virnoche > If you look closer you will see that the spacer bolts to the top of the strut using the factory bolts (you do not need to disassemble the strut like the daystar kit that makes you press the bolts out and replace with longer ones) I have grade 8 bolts welded to the top of the spacer that bolt to the factory mount like the stock bolts. The spacers are made out of 1/4 " plate and are pretty heavy duty.
Gas mileage change?? Haven't checked, not sure why it would change except for maybe not as aerodynamic with out the stink bug wedge look.
1BadTitan> I might build some more sets, I need to see what it really cost me to build them.
S4Titan is offline   Reply With Quote
