Old 05-03-2009, 05:02 PM   #7 (permalink)
loufish
loufish's Avatar
Re: Trailer Lights and Wiring Harness
To the OP:
You said you had all the lights at one time, then you must have all the relays. The relays very rarely go bad...
Turn/brake signals come from the BCM and a very popular TSB as already posted adds 2 "hidden" fuses in a BCM harness adapter.
These 2 extra fuses are pretty much unknown to Nissan techs & service writers, they are also NOT included on wiring diagrams...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
