Used the rustoleum two part product about 8 months ago as my garage is converted to a kennel for my hunting dogs. The paint is chipping in areas but looks great overall. Be careful to seal joints perhaps with elastomeric caulk- I didn't and think I'm getting moisture under the paint through the seam between the two parts of the slab. Would do it differently next time, but not sure it's the products fault. Be sure to etch and scour the floor. I would also recommend renting a high pressure washer to thoroughly clean the pores in the concrete before applying- this should assure good adhesion. There is no wear pattern from the traffic areas so I think the product is pretty good- just some chips, but not sure why.
