The struts with spacer will slide right in without much effort.
You will need to unbolt the top ball joint from the spindle, unbolt the steering tie rod from the spindle and unbolt the sway bar attachment point to the lower control arm. Not real hard at all, takes about 20 to 30 min per side.
You will also need to get the front end aligned after the install.
