Old 08-16-2004, 12:02 PM   #14 (permalink)
Sammy Sandbag
Sammy Sandbag's Avatar
Originally Posted by virnoche
Sammy-
COMPLETLY untrue!!! The daystar kit adds preload the coil and retains the exact unloaded dimension limited only by the strut itself. S4's solution adds 1.5" to the overall length where it mounts to the vehicle. I put my Daystars in so I know that there isn't enough drop in the lower control arm to just pry it down and squeeze another 1.5" in......
Easy killer, what I said wasn't completely untrue. I said the A arms are free to travel until they max out. If that extra 1.5" will max it out, I can't say as I didn't take note. However there is a top spacer, probably .5" that goes between the bucket and shock, so there is at least that much room for movement. It still slides into place, you just have to do what was mentioned above.
-Counsel Yourself
