Originally Posted by cougar
Anybody know what the tow mode is suppose to do ? I don't see any differance.
Cougar,
I've tried it all different kinds of ways, and here is my humble opinion:
It changes the shift points in D if you're towing something fairly light.
You want to tow in Manual 4 if you're towing something heavy. Period. Towing in 4 is a delight. Smooth operation, the truck will out-tow even Powersmoke trucks. The truck is a delight to tow with when you tow in Manual 4.
Now then:
What it SHOULD do is change the shift points in D, plus keep the tranny from hunting. We tow a 6800# Arctic Fox travel trailer and if you're in D, the trans will act as a 'hill-finder' and shift constantly back and forth between 5 and 3. What it does is wait until the engine bogs past the range of 4 then goes directly to 3 (or 2 -eeek!) until it gets enough speed to shift up.
I would [SIZE=4]GLADLY[/SIZE] go into the dealer for a memory flash to fix this.
Hello, Nissan, are you listening?
Steamguy
Finally found an appropriate sig pic. It's good at least through August...
