Old 05-08-2009, 12:13 PM   #4 (permalink)
Blackbeauty
Blackbeauty's Avatar
Re: New guy needs help
You will need to remove your shift knob. It just twists off.
You will also need to remove the shift console - it is what surrounds the shifter.
To totally remove the center console, there is a screw on each side of the front where it is under the heater control panel. You will need to get those as well.
Other than that, it should come out.
The Following User Says Thank You to Blackbeauty For This Useful Post:
MikeG (05-08-2009)
