Thread: trailer brakes
Old 05-13-2009, 05:31 AM   #63 (permalink)
jsnbrd
jsnbrd's Avatar
Re: trailer brakes
Originally Posted by Quartz View Post
If you already have the 7 pin connector and a hitch chances are you already have the relays.
I didn't have the hitch but everything else minus the relays. Don't understand it but it was listed as having the tow package. U-haul will have your relays. I did install my relays and thought that installing those relays would provide 12VDC. do I need another relay for 12VDC at the hitch? Also after installing the relays I tested all the leads due to my 7-way connector being removed and all but the left turn blinker worked, minus the 12VDC. I spliced the tail light to make for short installation. Anyone know the correct fix for the left blinker not working on the factory installed wires? I'd like to not have to splice any wires.
What is involved in installing a 12VDC relay if necessary to get that at the 7-way? or would it be just as simple to run a new wire from another connection. I don't have any other pre-plugged relays at the relay box.
Anyone? Anyone?
Beuler?
jsnbrd is offline   Reply With Quote
