Thread: trailer brakes
Old 05-13-2009, 06:09 AM   #64 (permalink)
mjw357
mjw357's Avatar
Re: trailer brakes
Originally Posted by jsnbrd View Post
U-haul will have your relays. I did install my relays and thought that installing those relays would provide 12VDC. do I need another relay for 12VDC at the hitch?
12v is only present when the truck is running, you might already know that.
Anyone know the correct fix for the left blinker not working on the factory installed wires?
Not sure what year your truck is, need to check for fuses at the BCM.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
