Re: trailer brakes
What is involved in installing a 12VDC relay if necessary to get that at the 7-way? or would it be just as simple to run a new wire from another connection. I don't have any other pre-plugged relays at the relay box.
As already posted, 12v only with key on, and if that's not working then you could be missing the relay, or blown the fuse...
The BCM probably has the BCM harness TSB performed which adds a small sub-harness containing fuses for left/right and brake....Those fuses are under the lower dash right by the steering column
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
