Originally Posted by boomn29
Ok, time for another newbie question. I've read up a lot, but want some information on my specific model - 04 Titan XE KingCab 4x4 - non big-tow.
Just bought my Titan last week and picking up an empty 18' car trailer tonight - and towing my car this weekend. My truck has a drop hitch and 7-pin connector already.
I know I need a Ball Mount (2 5/16") and an electric brake controller. Does the EBC plug into the 7-pin harness? Just wanting to verify what I need to buy.
Originally Posted by mjw357
Look in the fuse box under the hood, passenger side, behind the battery, black plastic cover.
Attachment 79828
If you have relays where I have circled, you are good. Otherwise, go to the closest U-Haul and buy the relay kit. About $25.
Thanks, I did not have the relays!
Picked up the trailer last night. I needed the 7-pin adaptor from Autozone and the relays under the hood for the running lights to work.
Since it was empty, I didn't worry about the electric brakes. I did get the Prodigy controller and will install that tonight.
It's an 18' Aluminum ATC Trailer that I will use to pull my 06 Mitsubishi Evolution to the track. Should be towing with it this weekend!
