Old 05-17-2009, 11:00 PM   #12 (permalink)
loufish
loufish's Avatar
Re: Trailer Lights and Wiring Harness
I am having this same problem with my running lights. Did the relays work? any help would be appriciated.
Same problem?.....You had lights, but now they're gone?....If you had lights, then it must not be a relay issue...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
