Re: Trailer Lights and Wiring Harness
I went to All About Nissan and cannot seem to find the TSB about the 2 hidden fuses in the BCM harness adapter... Any thoughts on locating this?
Also, I am taking the truck to the dealership tomorrow, but want to ask if the service techs know about the 2 hidden fuses in the BCM harness adaptor you speak of? Or should I mention this to them?
The BCM runs the rt/lt brake and turn signals. The TSB added a small sub-harness right off the BCM, located right around the steering column above the brake pedal area. The sub-harness is usually white in color...
I'd look for this myself before paying someone at Nissan to be stumped because very few techs know anything about this...By all means, let the Nissan guys know that's there's a "hidden" harness off the BCM that contains 2 fuses...
Print this and bring it with you....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
