Mike, All of these electric shift transfer cases like to be under no load when they shift. It will shift in or out best if you aren't loading the gears...in other words, you are not accellerating or decellerating. Just hold you speed for a little while.
Stopping usually does the same thing, and turning on dry pavement is actually hard on things. Turning may have "unloaded" the gears and allowed the transfer case to shift, but I don't recommend it. You might try stopping and putting the truck in reverse...you probably won't have to move, but it should shift when you do that.
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
