Re: two trailer questions
Originally Posted by motosyco
i just realized that i left out that when i un-hooked the eletric hook up the trailer brakes were still locked.
That's odd. Sounds like an electrical problem. Until you said that I was going to say that your brake controller was probably mounted at too much of an angle and then you were on a slope and that made it worse. My Prodigy is also mounted at the bottom of the dash but I used some bushings to it would be almost level.
Jim
