Originally Posted by motosyco
i think it has to be the emergency cable. hopefully it was just not in all the way or a one time freak problem. either way still going to take a look around under the trailer.
If it is just the breakaway switch, it's a very easy fix, and a cheap part too.
Breakaway Switch
If you are good with electrical stuff, just disconnect the two wires to the switch and check for continuity. Pin in should be open, pin out closed. I doubt the switch is bad, though, it's a pretty simple thing. The pin is probably getting pulled.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
