Old 06-06-2009, 01:36 AM   #2 (permalink)
titaninak
titaninak's Avatar
Re: help !!!! power mirror mod...
are you switching from big tows to non tow mirrors? , I don't think your going to have any luck getting powered mirrors for your xe unless your an expert at wiring with some se/le "powered" mirrors as the harnesses for the higher end mirrors are specific for their functions. can you be more specific.
I did the swap from big tow to non tow mirror, I have an LE and I had to get LE mirrors for the harness to work. se to se mirrors , you cannot use LE mirrors if your and se, xe, the harness will not work unless they are the same trim.
2006 LE, CC, BT, 4x4-Blizzard White
titaninak is offline   Reply With Quote
