Old 06-12-2009, 10:18 AM   #504 (permalink)
honeykeeper
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Re: Here's # of Rear Diff Failures Reported
Originally Posted by ADK Stomp View Post
Hi everyone, hope all is well,
So, I brought mine to the dealership on Monday after I noticed the "pumpkin", or what I think is the rear diff, was leaking was leaking pretty good daily for about 3-4 days. This is the report I got back from them (after two complete days in the shop):
"2 seperate fluid leaks from rear diff. Pinion seal failed, right rear axle seal failed. R and R all parts necessary and replaced rear diff pinion seal. R and R all parts necessary and replaced right axle shaft, seal and associated parts. Topped off fluid. Road Tested".
Is this a failure? Should I worry more that it won't be a permanent fix? The truck has 53K and the warrenty is up in 7, obviously. Since the fix, it feels pretty tight actually, but yesterday noticed an annoying squeek coming from the rear right side. FYI, I also intalled a magnaflow exhaust last Saturday (sounds great), but I don't think the squeek is coming from that.
I went to bring it into the dealership today and while driving there, the sqeak had gone away. It was raining pretty hard, but my radio was off and I didn't notice it one bit. What's up with that? Does anyone have any advice if I should do anything else for the moment. It would be appriciated and I am a noob, but trying to learn all about the Titans daily! Thanks.
Cheers.
If you have the original "spider gears" I'd ditch it and go with True-Trac A.S.A.P.....they should have replaced it.
On the squeaks could be:
1- Red Rubber boot rubbing on the rear shock if it is the OEM Rancho
2- Leaf spring bracket rubbing on a leaf....can lube for first fix and bend the braket out for a "final-fix".
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra L B, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and 75-90 in Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
JFK http://www.youtube.com/watch?v=J8dLHZ6jKFc
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
