Old 06-12-2009, 10:45 AM   #505 (permalink)
WindsorFox
WindsorFox's Avatar
Send a message via ICQ to WindsorFox Send a message via AIM to WindsorFox Send a message via MSN to WindsorFox Send a message via Yahoo to WindsorFox
Send a message via ICQ to WindsorFox Send a message via AIM to WindsorFox Send a message via MSN to WindsorFox Send a message via Yahoo to WindsorFox Send a message via Skype™ to WindsorFox
Re: Here's # of Rear Diff Failures Reported
Originally Posted by honeykeeper View Post
If you have the original "spider gears" I'd ditch it and go with True-Trac A.S.A.P.....they should have replaced it.
On the squeaks could be:
1- Red Rubber boot rubbing on the rear shock if it is the OEM Rancho
2- Leaf spring bracket rubbing on a leaf....can lube for first fix and bend the braket out for a "final-fix".
I know someone who had his rear axle replaced, do any of them have the Detroit rear or is that something you can only get by getting it done yourself?
"The problem is almost certainly a big spider's nest. I
can't wash my hair in the sink anymore, because of the paralyzing
fear that a mutated, poisonous sink overflow spider may leap from the
depths of the overflow and into my upturned nose." - Flaming Poultice
WindsorFox is offline   Reply With Quote
