Old 06-14-2009, 11:15 PM   #17 (permalink)
loufish
loufish's Avatar
Re: Guess what I'll be doing this weekend... *Teaser*
Well guys, I ran into some major technical issues while installing the MT kit. I started off with the right front. Took all the existing hardware from the prg uca I already had and put it on the MT uca like I was told. Went to put it back on and it was a no go. With the spacers in it wasn't going to fit. I didn't feel comfortable trying to force it in to slide the bolt thru. My guess is that the spacers from the old prg uca are not the correct one's I should be using for the MT uca???? I'm kinda upset because I was forced to put the old stuff back on. Anyone using the MT kit run into this issue? Should I have gotten different spacers for the MT uca?
Are you saying you used the rod ends from the old PRG arm and installed them onto the new MT arms?
Or did you just try to use the rod end spacers from the old arms?
Didn't the new arms come with all the hardware you would need?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
