Old 06-15-2009, 08:14 AM   #19 (permalink)
loufish
loufish's Avatar
Re: Guess what I'll be doing this weekend... *Teaser*
If you took one of the rod ends that normally gets threaded into the upper arm off the arm, will it along with the spacers fit into the the upper arm frame mount?
I'm trying to see if it's just the spacer, or did the arm "move" sometime during fabrication...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
