Re: Guess what I'll be doing this weekend... *Teaser*
I tried taking all the hardware off the rod ends and the uca still looks like its a tight fit.
How tight?....You might need to spread the frame ears just a bit to get the rod end & spacers in...They may have crushed a bit the first time....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
