Old 08-29-2004, 11:31 AM   #6 (permalink)
rvsixer
Originally Posted by Fab
The 26 foot Cougar with super slide has a 6,200 lb. total dry weight and 1,100 lb. pin weight, all within the Titans numbers. Add the 1,500 lb. boat/motor/trailer combination and we should still have pleanty of weight to play with.
1100lb pin weight, 180 lbs of gas, plus the hitch and you are pushing 1400+ lbs without any passengers or cargo. The payload capacity of the any Titan with tow package ranges from 1202 lb (CC 4x4 LE) to 1541 lb (KC 4x2 SE).
Either overloaded already or a very small driver only traveling machine depending on which Titan with this trailer. Any 1/2 ton simply isn't enough truck for this job.
rvsixer is offline   Reply With Quote
