Old 08-29-2004, 11:07 PM   #12 (permalink)
COTitan
Banned
COTitan's Avatar
dknb:
The titan is not rated to tow a 5 wheel, the 9500 is for TT with an SE KC with BT. So since you proved to yourself you have lighter truck that now means you can haul more with, it is that correct? The real reason nissan says you can't tow a 5th wheel is turning clearance of the short bed vs 8'
Technecly by weight you are very close to max(GCWR of 14,000lbs, 6400 GVWR ) which if you are going long distances with that load you will be more prone to failure. It is better to buy more truck if this is the reason you are buying this truck.
I'm buyin an 05 even though it is too small for some of my work truck use based on #'s, just so nissan will see people like the titan and release a Diesel which will have the capibility to do what i need. I plow and haul 8000+ regularly so if i used a titan i would just be ruining a 30k plus truck. I hate my ford work truck but it does what i need it to do until nissan or toyota releases a diesel 3/4 ton
COTitan is offline   Reply With Quote
