Re: Looking at this toyhauler good for the Titan?
That's going to be a VERY heavy trailer...A GVWR of 9,995lbs and a tongue weight of close to 1,000....That's a lot for a 1/2 ton truck...
Please don't believe the claimed empty weight of 5,505 lbs, try adding about 500 lbs to that....And that's before you load up a single bike or fill the water tank...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
