Old 08-30-2004, 10:01 AM   #3 (permalink)
titanjbc
titanjbc's Avatar
My guess is that the trailer has surge brakes, where the brake force is determined by the force of the trailer against the hitch. When you stop, the trailer pushes against the hitch, engaging the brakes. You should definitely confirm what types of brakes, electric or surge. If the trailer has surge brakes, chances are it has a 4 pin wiring harness for lights. If so, you can buy a 7 pin (what's on the truck) to 4 pin adapter for $10-15 at UHaul or Walmart. I hope that helps...
Titan SE CC 2WD
Smoke / Graphite
Pop. Pkg. w/Capt., Big Tow, Util. Bed Pckg.,
Splash, Mats, Fog Light Kit, Step Rails
Leer 100R Cap
Hornet Lite 24RS Travel Trailer
Reese Straight-Line Hitch (WD System with
Dual Cam Sway Control) Prodigy Brake Controller
titanjbc is offline   Reply With Quote
