newb with 09 XE max utility questions
Hi all, newb, first post, picked up my 09 XE CC LB 4wd in majestic blue a couple days ago. I got the preferred and max utility packages, with the intention of towing my Jeep loaded on the car trailer.
Being the detail person I am, I started going through the truck last night looking and learning. After reading up on the specs over and over from the Nissan website before ordering, I figured I knew what to expect.
First thing that caught my eye was the 650cca battery, as opposed to the 710 listed in the specs. I then started looking for the aux trans cooler as mentioned in the earlier years' Titans -- didn't see one, but I might have totally missed it.
It obviously has the hitch, 7 pin harness, and I already wired up my Primus using the pigtail in the glovebox. I checked and the axle has the 3.36 gears listed on the label.
I'm looking for a little validation that I'm good to go. My previous ride was loosing the trans, probably due to towing at or slightly above the limit, and I dont want to go through that with the new Titan.
Lastly, I'm still in break-in, no problem getting to 750+ miles by next Thursday before I leave on my first towing trip. I was going to drag an empty trailer to/from work for a couple days and maybe take the loaded trailer the last day (about 30 miles each direction) before leaving next Thursday.
Thanks for hearing out a newb with a paranoid tendancy,
Iz
