Re: SAW pre-load height?
I could crank mine to 2.5" of thread showing to get to the 3" of max lift (2wd)? Maybe a question for Blackbeauty. Thanks for the input.
You can crank them to 2.5" until you get the lift spindles, but of course the ride will suffer...Try 2.25" and just deal with it until you get the other parts.
If you spend most of your time just looking at your truck, then crank it to whatever, BUT if you spend way more time driving it, then set the preload where it's comfortable to drive...you know you have more parts coming...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
