Old 06-27-2009, 03:03 PM   #3 (permalink)
Hawaiianbasshead
Hawaiianbasshead's Avatar
Re: Need Advice on improving mid range and top end
I own/have both the volant and aFe and I kinda think the aFe has more low end but the volant I think may have upper end really trivial. on exhaust larger diameter or duals would be better for mid/upper one pretty common misconception I see thrown around alot is midrange and topend power meaning speedwise. exhaust will control rpm power but not so much speed which is more a side effect of where u make your peak power. so you plan on running your motor into higher revs or get more pull from 40+mph? this is a huge difference imo, more pull overall is on thing that would make a huge impact on pull @ 40+mph. intake exhaust and any handheld will get you quite a bit more pull imo.
so if you want a catback for high rpm I'd say probably the nismo dual setup is a good one. if you want to keep your pipes and just swap mufflers I'd say something that's a flow thru design not a baffled muffler like the spintech. the bullets would be flow thru I think. as well as other glasspacks and the powersticks ( I just ordered me a powerstick ) and as little bending/bends as possible would also be good for either. a JBA catback I'd recommend for more all around pull. this is going by piping diameters and judging from other peoples titans. I understand airflow and can somewhat apply it to exhaust setups so I'm comfortable with those two recommendations. they are also the most popular for a reason. I think the JBA will leave you more cash for an intake and programmer. I'd recommend getting both used so u can get all three instead of just intake and exhaust I've seen intakes for around $100 and programmers for about $240...
and the JBA can be had for around $400 so for about $700 you should be able to get all 3 or just the nismo catback really depends on your plans and what you mean by mid/high end power speedwise or rpm high reving power...
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
