Can i tow the above mentioned without killing my truck?
Tow what?.....Why in the world would you expect anybody to know the answer to that question when you haven't told us what the trailer weighs while going down the road?
WHO cares what the empty weight is on ANY trailer, do you plan on towing it completely empty, no propane, no batteries, nothing loaded in the trailer at all?
Now that eing said, is there any other way to tell what you may or may not tow?...Maybe there's another spec out there somewhere that you CAN use for a reference...Let me think...Can you think of one?....
My sarcastic reply is because I think Ill throw up in my soup if I read one more post where somebody asks about towing an EMPTY trailer when the manufacture gives you a perfectly good spec called Gross Vehicle Weight to go be...
Why would you buy the trailer first and THEN ask this question?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
