Old 06-28-2009, 09:44 PM   #13 (permalink)
loufish
loufish's Avatar
Re: more advice on hauling 29' travel trailer
gross weight is 6422 lbs.
Where did you get that number?
The link you posted was for a Hideout Model 27B which does list the empty weight of 4888 lbs (a lie, it weighs more then that when delivered...) and a cargo rating of 2732 lbs....It's simple math ...4888+2732 = 7620 lbs...
That's the GVWR of that trailer, 7620 lbs...That's the number you use for any truck to determine if it can be towed or not....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
