Old 06-28-2009, 09:47 PM   #7 (permalink)
loufish
loufish's Avatar
Re: Do I have Big tow or not?
I would make sure you add, if someone has not done it already, the finned aluminum differential cover and change the diff fluid to what is required now Synthetic 75w-140
A very good idea!...Even if you can't get your hands on a factory finned cover right now, I'd drain & refill the rear end oil...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
