Re: Leveling kit? Need one mounted above assy.
It bolts on top of the coilover...you remove the whole front 'shock assembly'...and bolt the spacer onto the 3 studs.
Then you rotate the assembly 180-degrees, and bolt it back in place.
No disassembly of the strut/spring, they just bolt on top of the strut.
- Brian
'05 TITAN CC SE (2" level - Bilstein 5100's - 22" Magnaflow - K&N drop-in - 20" Weld wheels (forged) - 275/60-20 Dueler Revo's)
'96 240SX (turbo'd track car - 325rwhp / 2700lbs)
'07 VW GTI (4-door - DSG - wife's daily driver)
