Old 06-29-2009, 10:44 PM   #2 (permalink)
loufish
loufish's Avatar
Re: OEM E-Locker on 4x2 Titan
Yes you could, just make sure you get the right E-loc for the right year...04-07 are all the same...08+ are the same.
You can get a TruTrac for 04'-07' Titans, the big advantage of a TT over the factory E-loc is that the TT replaces all the spyder gears....which is the part most likely to fail....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
