Re: Good lift set up
Originally Posted by mcclelland21
Get in touch with Greg from PRG he will give you a set-up to match what you want. IMO I would go with a stage 2 lift get rid of that spacer. Go with 35" Toyo M/Ts.
the saw coilovers listed get rid of the spacer and are better then the ones in the procomp stage 2.
That is a very good setup the op has listed.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
