Originally Posted by yamatitan
the saw coilovers listed get rid of the spacer and are better then the ones in the procomp stage 2.
That is a very good setup the op has listed.
Yep, you are on the right track for sure! The stage 1 eleminates the need for any Procomp spacers or coilovers (with the stage 2) which would be sub-standard to the SAWS in the first place. The CST swaybar endlinks are better than what comes with the Procomp kit. The Bilstein rears are also an improvement over the Procomp rears that come with the kit.
Now, if you need the rear pack that is a great setup, better than factory for sure and the trac bars would be icing on the cake!
That sounds like a really good setup to me, like mentioned before, call Greg at PRG if you haven't done so already...but it sounds like you have or have been paying very close attention to everyone else on here who is very satisfied with their setup.....good luck and you will like it if you decide to go that route!
