Re: newb with 09 XE max utility questions
How did you get SE wheels on the XE, must be part of the max utility package.
You are fine to tow, keep speeds to the limit and don't start off fast, just take it easy. change the oil at 3k and put some good synthetic in it.
Not sure about the battery but the extra power is only needed whne hauling a TT that requires 12v juice to power up the gas/electric fridge and MOST of the time a TT has a onboard battery. But if your specs call fro the bigger battery the dealer needs to install one.
Tow in 4th and on hills just drop to 3rd without giving it anymore gas an you will be fine.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
