Originally Posted by Shane06fl
How did you get SE wheels on the XE, must be part of the max utility package.
You are fine to tow, keep speeds to the limit and don't start off fast, just take it easy. change the oil at 3k and put some good synthetic in it.
Not sure about the battery but the extra power is only needed whne hauling a TT that requires 12v juice to power up the gas/electric fridge and MOST of the time a TT has a onboard battery. But if your specs call fro the bigger battery the dealer needs to install one.
Tow in 4th and on hills just drop to 3rd without giving it anymore gas an you will be fine.
Its the preferred package I think, you get a chrome grille and different wheels. Not sure from what the wheels come from, but I know its not the 08+ SE, im guessing its the older SE. Not clue whats different on the interior, id guess cd changer
