Re: A/C Condenser Fan Recall Question
Be careful on the fan recall, I had mine done, replaced the fan and new harness, but the check they do is only straight to the harness, which bypasses all power normally applied to the fan. Mine was in for an axle seal replace, which they replaced the whole axle now, and told them after the replacement of the fan, I have yet to ever hear the fan on, it is hot now up here so they found the 40 amp fuse blown. My last fan was seized on my 06, so make sure they check that fuse if you have to have a fan replaced or the recall done period in my opinion. The test they use does not use vehicle normal harness power to check on the recall. Just a tip for those out there.
2006 Titan SE CC Granite, S&B Intake w/ AirRaid TBS, Superchips Cortex, Big Tow w/ 18" Chrome Six Spokes, Active Tuning Grounding Kit, Axle Vent Mod, Mag-Hytec rear diff cover ,True Trac, Armada front spoiler,and Cowl painted. Nismo stripe kit. Katzkins leather interior. Stillen Dual Side Exit Exhaust, Stillen front sway bar w/PRG end links. PRG mini lift, Bilstein 5100's, PML trans pan w/guage set in Lo-tek pod. All Amsoil fluids, of course, I am a dealer. Not one piece of WRP Technology junk on it.
