Old 07-03-2009, 05:39 PM   #2 (permalink)
loufish
loufish's Avatar
Re: Left signal on trailer doesn't work
If the left trailer brake light works, but the left trailer turn signal doesn't, you have BCM (Body Control Module)issues.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
