Old 07-03-2009, 08:47 PM   #1 (permalink)
mxracer450
Electrical problem with brake controller
I have read most of the posts and havent seen this problem Iam experiencing... I have an 06 titan with the BT package. I purchased a primus brake controller by Tekonsha, wired it into the nissan harness that plugs into the elec. brake controll plug-in under dash. Everything seems straight forward but now it says it is connected when there is no trailer. When a trailer is plugged in it still says connected but the trailer brakes do not work(trailer brakes work fine when plugged into chevy, not prob. with trailer). All trailer lights work properly. Some times it says it is disconnected when you plug a trailer in. While towing if you turn on driving lights the controller says trailer is disconnected. Now for a new twist, the brake lights (truck) stay on no matter what, this happened about a week after controller install. I cannot get brake lights to turn off, had to disconect battery. All relays are there, not sure if they are functioning properly however. could this be it? something else? anyone else had this problem?
Thanks for your help I need it!
mxracer450 is offline   Reply With Quote
