Old 07-04-2009, 10:45 PM   #2 (permalink)
loufish
loufish's Avatar
Re: Electrical problem with brake controller
Did you run the adapter harness from Tekonsha, or did you wire it up?....You might have some crossed connections...
Check all that first...
You might have a bad controller back feeding the truck brake curcuit...or issues above...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
