that doesnt sound good at all, why would you want to use your titan that close to its limits??, youll eventually hurt it
For almost every guy towing theres 2 camps...
1) My truck is rated to tow x,xxx lbs so there should be no problem doing so, and the manufacture should already have a safety factor built in.
2) Why kill my truck, so I'll tow no more then 75-80 percent of it's rating and my truck will last a little longer....
I'm not going to bag on the camp I'm not in, but IMHO I just don't believe in towing at 100% except for short tows...And I'd feel the same way if I had a 3/4 ton truck, too much trailer for that and I should be looking for a 1 ton truck...
Where things in my mind get real sticky is too much length.... A 33 ft trailer is a whole lot of tail wagging the dog for a 1/2 ton truck...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
