Old 07-06-2009, 05:57 AM   #4 (permalink)
loufish
loufish's Avatar
Re: Code c1142 - Pressure sensor (ABS)?
Ok...you've got this posted in like 4 different places....calm down and let the system work...
Check my reply:
ABS sensor......
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
