Re: Tow Package to recharge battery
The charging circuit on the 7 pin connector is for helping to keep charged batteries charged...It's not so good at charging them...You would be good getting 15 amps to the batteries, multiply that times the amount of time you tow and that will give you some idea of the overall charge you could get.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
