Old 07-06-2009, 07:46 PM   #6 (permalink)
loufish
loufish's Avatar
Re: Code c1142 - Pressure sensor (ABS)?
Here's the deal....
There's 2 sensors, and most likely the code is from a bad sensor, BUT the code doesn't say which one...
You can do a visual to check the wiring, dis-connect, re-connect to check for corrosion. If you feel it's just a bad sensor, then replace just one, clear the codes and start all over...If the light stays out, you got it on the first try, if not, then switch the sensors front and rear, this will take care of you issue if it's the sensor...Check the price for one...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
